tundra
what is this air filter, i have look in many place and all i see is filter with steel wire and fiberglass filter
thnaks
thnaks
Go back to my last post and click on the link. You have to take your air screens off and then place the filter material over top of these screens you took off and then reinstall them. They will hold in place with friction due to a tight fit.
tundra
i know, but where did you find those materiel, i'm unable to find something that will do the job.
thanks
thanks
Oh ok you can use black pantyhose stockings or go to a hardware store and buy the white 3m air filter material for a hammock style filter for your house furnace.
Make sure to ask for hammock style filter material for a house furnace and the store clerk should be able to help you.
tundra
filter is in like your i think, i will try that this week-end.
thanks
thanks
yamahajunkie
tundra said:filter is in like your i think, i will try that this week-end.
thanks
Should work for you bud let us know!
tundra
not working or snow came inside by another place.
Whereeeeeeeeeeeeeeeeeee
I rode all day at Boulder in Revy for two days with no problems after putting the cowling air filters and changing skis. Mind you I still have the stock air box on.
mmmkokanee
i have to tape the 2 front hood vents shut in deep powder with the filters and prefilters on...got some black duck tape and trimmed it to look like it should be there.
Easy to remove and I keep some wrapped around a small film container if i need more.
Never had a problem with it overheating yet.
yamahajunkie
tundra on your evac kit, are you using the catch cant to the little filter by the steering stem, or straight out the case to the filters?
MT RX1 Mountain Man
ECP Freeze up
I just ordered an ECP and am hoping that it will be worth it and not freeze up! I did see while thumbing through the new Dennis Kirk catalog that on page 269 you can now buy Outerwears pre-filter material by the sheet from 12"X 12" up to 36" X58". I was thinking of buying some and putting over the vent screens if I have trouble.
