LeeKo
How high can you go without changing cables?
thanks
LEEKO
thanks
LEEKO
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
i was wondering the same i don't think 2'' will be a problem.
2BLUE4U
I have a Rox 3-1/2" Pivoting on my Attak. No need for cable extensions but I did re-route the throttle cable under the bar instead of over it. All other cables are pretty much fine.
I mounted the ROX pivoting 4" to 5.5" on top of the ROX mounting bar wich would not fit inside the trim ring so I installed an RX-1 stock mounting block uner that that gained me 1.5", The net affect is with the bars in the lowest position they were 2" higher and 3.5" in the up position. I had to change to a mountain cable when the bars were in the full up position the motor reved when the bars were turne to the left. At the down position it was OK.
nb-attak
nice sled 2blue4u. off topic but how is the paint holding on your side panels. side panels are fairly flexible.
2BLUE4U
nb-attak said:nice sled 2blue4u. off topic but how is the paint holding on your side panels. side panels are fairly flexible.
Thanks nb, I guess I can't really tell ya. I just had them painted a couple weeks ago. I know other guys on the site have done it and said they hold up just fine. More pics of my sled....http://www.ty4stroke.com/viewtopic.php?t=63476
charger0926
- Sep 3, 2008
- Elk Grove, CA
- 2012 nitro mtx 162
DID YOU USE THE PIVOTING STYLE OR THE ADJUSTABLE STYLE.Yamadog said:I mounted the ROX pivoting 4" to 5.5" on top of the ROX mounting bar wich would not fit inside the trim ring so I installed an RX-1 stock mounting block uner that that gained me 1.5", The net affect is with the bars in the lowest position they were 2" higher and 3.5" in the up position. I had to change to a mountain cable when the bars were in the full up position the motor reved when the bars were turne to the left. At the down position it was OK.
I USED THE ADJUSTABLE AND THEY JUST BARELY FIT IN THE CHROME TRIM RING?
A VERY NICE PRODUCT NONE THE LESS
