mshabaz
- Aug 16, 2006
have the 2" rox riser on 06 apex now,,need to go taller. i'm 6'2 and still hunch over with these. how tall of a rox can you go without new cables??
rox raiser
I raised my seat 4" and the Rox Raiser that I had was 2" raiser, but needed to replace with 5" Rox raiser and had to purchase a cable extension but the brake hose still worked without being too short.
2BLUE4U
I have a 3-1/2" Rox Pivoting Riser on top of the stock block and my cables are fine but getting tight.
mshabaz
- Aug 16, 2006
which cable extension did you use on the 5" riser,,did you just buy the apex mountain cable??
YamahaFreak
The Pen is Blue
- Nov 26, 2009
- McHenry, IL
- Sr Viper XTX SE
Yes same here and it will not let me get another cm, I'm pretty sure that's it's limit!2BLUE4U said:I have a 3-1/2" Rox Pivoting Riser on top of the stock block and my cables are fine but getting tight.
RISER 5" CABLE
I USED A CABLE EXTENSION FROM POWER MAD THAT ADDED 10" TO THE THROTTLE CABLE, MORE THAN ENOUGH FOR A 5" ROX RISER ON AN APEX. THINK ITS ABOUT $28 US FOR THE EXTENSION.
