yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I tried to run to live data while testing out my sled.
Turn on gap app on phone I pressed find device
Then went to dashboard and select
Rpm speed knockdetection and boost pressure
Nothing came up it just had "NA" for each for each selected option.
I checked the manual but I can't find what I.am missing to get it to start live log?
It was my first ride after adding cold air intake, 3 bar map sensor and turbosmart bov to my hurricane stock muffler flash
WOW!!! WHAT A DIFFERENCE FROM JUST flash!!!
This thing is a complete animal!! I had to change my shorts after hammering the throttle on the 270hp!!!
It's been a long time since a sled thrilled me like this!!!!!
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
This is what Yamamarc showing
You have to purchase the data logger feature and make sure your communicator is updated with it on there. Then you will have the ability to set whatever display options you want to monitor...ie. boost, AFR, intake temp and such
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Live data is included you have to purshase data logger to recordYou have to purchase the live data feature and make sure your communicator is updated with it on there. Then you will have the ability to set whatever display options you want to monitor...ie. boost, AFR, intake temp and such
Yeah, you're right. Long day...... Have you tried uninstalling the app and reinstalling?Live data is included you have to purshase data logger to record
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Mine does the same once in a while. Seems to be a glitch in the software. Typically if I turn the sled off and restart then reconnect it will work.
The first time I used the app it was a bitch to connect, but has been fine ever since a reinstall.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Ok I'll try again tomorrow! Thanks!Mine does the same once in a while. Seems to be a glitch in the software. Typically if I turn the sled off and restart then reconnect it will work.
The manual says it will automatically run data log. Just wasn't sure if there was a setting or something that needed to be turned on?
Mototown
- Sep 11, 2018
- Apex 40 th
I had same problem, I had to close everything on phone & restart phone . Also phone needs a good charge to work properly.
Wingwong
- Mar 20, 2018
Hi
What is your track setup yamamarc
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
2019 zr 9000limitedHi
1 1/4 stock track with 144 woodie's 1.450 megabites 2 double.2.single
Wingwong
- Mar 20, 2018
2019 zr 9000limited
I’m looking at the gold diggers, are the megabytes better?
WinterWolf
- Mar 25, 2017
- Connecticut
I think the Megabytes are a lil more durable/tougher for everyday trail riding.
I’ve had both and I like both...but the last few sleds I’ve used the megabytes and have had great success over a long period of miles. Jmo.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I have been running megabites on my last 3 sleds! They are a great trail stud imoThanks
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Thanks Pan
