How is live data activated with flasher
yamamarc
Massey Ontario
Canada
2019 zr9000 Ltd
I tried to run to live data while testing out my sled.
Turn on gap app on phone I pressed find device
Then went to dashboard and select
Rpm speed knockdetection and boost pressure
Nothing came up it just had "NA" for each for each selected option.
I checked the manual but I can't find what I.am missing to get it to start live log?
It was my first ride after adding cold air intake, 3 bar map sensor and turbosmart bov to my hurricane stock muffler flash
WOW!!! WHAT A DIFFERENCE FROM JUST flash!!!
This thing is a complete animal!! I had to change my shorts after hammering the throttle on the 270hp!!!
It's been a long time since a sled thrilled me like this!!!!!
This is what Yamamarc showing
You have to purchase the data logger feature and make sure your communicator is updated with it on there. Then you will have the ability to set whatever display options you want to monitor...ie. boost, AFR, intake temp and such
You have to purchase the live data feature and make sure your communicator is updated with it on there. Then you will have the ability to set whatever display options you want to monitor...ie. boost, AFR, intake temp and such
Live data is included you have to purshase data logger to record
The first time I used the app it was a bitch to connect, but has been fine ever since a reinstall.
Mine does the same once in a while. Seems to be a glitch in the software. Typically if I turn the sled off and restart then reconnect it will work.
Ok I'll try again tomorrow! Thanks!
The manual says it will automatically run data log. Just wasn't sure if there was a setting or something that needed to be turned on?
I had same problem, I had to close everything on phone & restart phone . Also phone needs a good charge to work properly.
Hi
What is your track setup yamamarc
2019 zr 9000limited
1 1/4 stock track with 144 woodie's 1.450 megabites 2 double.2.single
I’m looking at the gold diggers, are the megabytes better?
I think the Megabytes are a lil more durable/tougher for everyday trail riding.
I’ve had both and I like both...but the last few sleds I’ve used the megabytes and have had great success over a long period of miles. Jmo.
Ok got my flasher from Hurricane thanks to Marc awesome tool. It’s all working mint and tried txt you Yamamarc and not going threw
Thanks Pan
