snoman
exactly how much oil does the apex needs ? i put in 3.5 is that too much or good.
apltx08
With filter change and motors base drained out your OK...after your 1st ride check your level, you should be fine.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
you should be darn close.....ive put less in and alittle more in then that before with filter changes...
the key is to warm the engine fully,then check your dipstick without screwing it down....and get it at the full mark.
Dan
Dan
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Should be real close with 3 1/2 check it without the stick screwed in.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
3.8 is the capasity of the system. If you change the oil filter is would be 3.5 liter. If you don't change the oil filter you only need to fill 3.2 liter approx.
The last drops of oil are still in there somewhere when you drain it
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
ttt
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
tttwod
