oil change
scar
Regina,Saskatchewan
How much oil do you put in the Apex.Manual says with oil filter change 3.2 quarts.But then it says total amount 4.0 us quarts.I changed the filter.
I just did mine and i change the filter,remove the drain plug on the bottom of the motor,remove drain plug on the reservoir and put exactly 3.8 litre like the manual said. 3.8 liter =( 3.3 imp qt,4.0 us qt).
