northernguy10
I have a 06 attak with 1 1/4 track, but was wondering if a 1 3/4 would fit. was planning on trying a little more off trail/ mountain riding in newfoundland this year on my trip. any help would be appreciated
thanks
thanks
AllagashX
probly not without removing the protectors. My 1.5 ripsaw use to even rub, I had to trim down the lugs where the tunnels where and then I was allset
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
So you bought a new track, and then cut off part of the lugs?????
You should have removed or modified the tunnel protectors!!!!!!
I am going to gues that your track won't last as long as it should, an you will start to notice odd vibrations.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
nate007 said:So you bought a new track, and then cut off part of the lugs?????
removing the protectors is twice the work and if you ever decide to stud then you have a days work reinstalling and welding the protectors back on. trimming the lugs makes no difference on track life. I know guys that have shaved thier 1.75 tracks down to 1.25. All allagashx did was notch the lugs that are over the windows so they wouldnt rub on his protectors anymore. A utility knife and 20 minutes is all you need.
northernguy10
did you notice alot of improvement with 1.5 ripsaw?
justinator
- Mar 25, 2007
- Maine
northernguy10 said:did you notice alot of improvement with 1.5 ripsaw?
allagashx had the 1.5 ripsaw installed before he took delivery of his sled but I will tell you that my 1 3/8 sno pro track is wayyyyy better than the ripsaw, on trail and off trail.
SERPAGS
Speaking of tracks, what is the life of a track for a hard trail riding style?
grader
tracks can be destroyed easily in a few miles or made to last thousands. trail and riding conditions are a big part of track life. heat is a major killer when running high speed with low snow. spinning out on roads and rocks kills them.
