How to adjust toe out on Nytro
Skiduty
Iroquois, Ontario
Canada
2008 Yamaha Nytro, 03 MXZ 600, 02 MXZ 500F, 05 600SDI
I’m trying to adjust the toe out on my right side ski. I have the hood, right side fairing and right side lower fairing off, from what I’ve found I have to loosen the inner and outer jamb nut on the tie rod? Then turn the tie rod shaft that goes through the tie rod inner boot? Is this correct? Oddly, I never get any search results for working in a Nytro on you tube. This would appear to be a game of guesstimates as I have ran string don each air of the track, measured the handle bare back to same spots on each side of tunnel, but 1/32 here, a 1/64 there. It’s not a precision deal as 1/64 over 8 feet of string is well,, I don’t know but a bit. Do I need to take the nose fairing off to get to that inner jamb nut?
