Toe Out
SledFreak
Ontario. Canada
Canada
Current 2020 ThunderCat. - SOLD!
I'm trying to adjust the toe out on my sled, but I can't find the inner jamb nut for the inside of each tie rod. I can loosen the outer one, since it's starring at me in my face, but I cannot change the inner, because I can't find it. I felt all the way up the boot and can't feel it, but how far is it? Do I have to drop the belly pan? Where are they? Any help would be appreciated.
Just pull the rubber boot partially out, turn the skis, and you'll see the inner nut. Remember, the outside is reverse thread, inside is standard.
So, that is the way to do it, is to pull the boot out (Partially). How do you get a wrench in because, I can't even feel it in the boot? Any more info.... This is a pain in the #*$&@......
I literally just did mine this morning. Trust me, you can get a 14mm wrench on it fairly easily. Once the boot is back, you have to turn the skis hard and you'll see the inner nut.
Good tip there Kubota
I do it a little different, turn the ski to the extreme, push the boot all the way back and you can just get to the nut.
toe settings
I just needed a slight bit of toe out so I unbolted the tie rod end from the steering arm and turned each side 1/2 turn and bingo 3/16" toe out. Did not have to mess with the inner lock nut.
