347strokin
How do I get my TPS out?
Does it just pull straight out once the bolts are out?
There is a coolant hose directly behind it which wants to force the TPS unit upwards. I just don't want to break or bend anything here.
347strokin
Alright I got it.
Just had to pull it out a bit further.
Shootinstick
Had a feeling you were still going to end up changing it. When you said it the readings would go up and then drop to zero, it was intermittent like mine was.
347strokin
Yeah,
I got 2 more good rides out of it and then I noticed it wasn't idling right and it was running a bit rough. Sure enough the diagnostic shows way off and it won't even get near the parameters now.
