aduesling2
How do I remove the stock seat on an 03 rx1? Any tricks/tips that might hang me up? Thanks, Al
mbarclay
you remove the exhaust end caps, rear pastic trim(around taillight) then when thats off youll see 2 "rods coming from under the seat with a 10mm nut on the end remove the nuts and you can lift the seat off up by the tank theres a wire connector you can unplug if your taking the seat completly off its for the taillight
