gpxsrx
- Dec 15, 2009
- way to many 2 strokes
Who is running the recommended rpm on the 190 Hurricane turbo
8700 @ 193 hp ?
I have been running 9050 -9200 on hard launches.
STM weights 60
11.4 grams in Heel
Mid empty
4.4 in tip
74.8 total grams.
Just wondering should I load the heel or tip to bring RPM down? Thanks
8700 @ 193 hp ?
STM weights 60
11.4 grams in Heel
Mid empty
4.4 in tip
74.8 total grams.
ricer68
- Mar 23, 2016
- Wabash Indiana
- 2007 Yamaha Apex GT
- North East Indiana
What springs and helix are you running?Who is running the recommended rpm on the 190 Hurricane turbo
8700 @ 193 hp ?
STM weights 60
11.4 grams in Heel
Mid empty
4.4 in tip
74.8 total grams.
DTJ
- Mar 31, 2016
- Brainerd, MN
- 2023 Yamaha Sidewinder XTX
2017 Yamaha Sidewinder BTX
I'll have to check where I have the weight but I'm pretty sure I have my STMs at 76 grams total. 8800 rpms. Purple secondary spring and 51/43 helix. I also run the gates carbon fiber belt which is a little tackier and brings rpms down about 300 from stock belt.
gpxsrx
- Dec 15, 2009
Stk secondaryWhat springs and helix are you running?
OPO primary
BSB to lame
gpxsrx
- Dec 15, 2009
DTJ are you running BSB primary spring?I'll have to check where I have the weight but I'm pretty sure I have my STMs at 76 grams total. 8800 rpms. Purple secondary spring and 51/43 helix. I also run the gates carbon fiber belt which is a little tackier and brings rpms down about 300 from stock belt.
DTJ
- Mar 31, 2016
- Brainerd, MN
Yes.
gpxsrx
- Dec 15, 2009
Wow no one running 190 Hurricane turbo anymore ? Must have jumped on the Sidewinder. Just looking to see how many people are running the recommended RPM@ 8700 ?
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I'm running around 8700 but I have the straightline header so I think I could rev a bit higher. It pulls hard even after it's clutched out fully with overdrive machining. I had it up to 9100 and would have gone farther if I held it
- Dec 4, 2014
- 2015 RTX LE- Hurricane Turbo
I have the hurricane 190 kit and am Running 9100-9200 top rpm - I have 14 grams in the heel and 0 grams in the mid and 0 grams in the tip running the hurricane clutch kit - 21/41 gearing on a 1.5 inch track. Pulls 100 mph in any condition and on hard pack I've seen 108 on the speedo never gps'd it.
Rev limiter is 9350
Rev limiter is 9350
- Dec 4, 2014
If you have Dave's kit it would be stm, mine is - I'm running the same helix as you as well
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
What rollers are you running? Stock 15.5mm?
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I have an MPI trail turbo runnig stock boost, not a Hurricane, but might be similar. I have been sorting out over-revving issues. My lastest setup (that I haven't been out to test yet) is Supertips weights with 11-grams in the heel, 6-grams in the middle, and 7-grams in the tip. I have 14.8mm primary rollers installed. I am running a Dalton Red primary spring and have an STM roller secondary with 46/40 helix and Arctic Cat Green spring. There are only 5 positions for spring wrap and they are all on the cover. I do not know what the wrap is in relation to a stock secondary but there are 5 positions in the cover and I have the spring set to the 2nd to least amount of wrap.
Primary weights have a total weight of 78 grams now. On my last trip out, they were at 73 grams total and I was hitting the rev limiter pretty easily and the dash recall showed a peak of 9350. I want to get it under 9000... preferrably about 8800.
gpxsrx
- Dec 15, 2009
My set up is the same now 2 tungsten in heel except I added 1 washer 1 o-ring 1-screw. Same results 107 mph gps. Going to have Hurricane machine my clutches at end of season.I have the hurricane 190 kit and am Running 9100-9200 top rpm - I have 14 grams in the heel and 0 grams in the mid and 0 grams in the tip running the hurricane clutch kit - 21/41 gearing on a 1.5 inch track. Pulls 100 mph in any condition and on hard pack I've seen 108 on the speedo never gps'd it.
Rev limiter is 9350
gpxsrx
- Dec 15, 2009
What primary spring are you using ?If you have Dave's kit it would be stm, mine is - I'm running the same helix as you as well
