HMTurbo
- Dec 5, 2017
- Midwest
- 2018 LTX-Le
Purchased this last spring and worked good for the one weekend. Now I get nothing but SD_24 code. I'm on my third new O2 sensor without any change. Any tips on what else to look for or check? Would it be possible for someone with this setup to post pics of the connection points?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
SD-24 code should go off on dash after sensor warms up. It only lights up upon startup for a little bit. This is normal operation.
If it stays on all the time, and you have changed sensors, the A/F module may be bad. There are lights on the module, read the instructions on the module about the light on the module. I had a module go bad once as I believe the snow and moisture killed it. I now have it mounted up front where it can't get loaded with snow and burn it up.
I replaced the module on mine and all was fine after that.
Edit: Mine was made by AEM. So yours may be different on the LED lights if it the other brand module, the ECU master, I've never seen that module myself to know if it has led lights on it.
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Do you have power to the module itself?Purchased this last spring and worked good for the one weekend. Now I get nothing but SD_24 code. I'm on my third new O2 sensor without any change. Any tips on what else to look for or check? Would it be possible for someone with this setup to post pics of the connection points?
HMTurbo
- Dec 5, 2017
- Midwest
- 2018 LTX-Le
I need to check. I didn't figure it would lose power after working perfect last spring.Do you have power to the module itself?
HMTurbo
- Dec 5, 2017
- Midwest
- 2018 LTX-Le
It doesn't go off after warmup. Don't believe the ECU master version has led lights but I'll check again.SD-24 code should go off on dash after sensor warms up. It only lights up upon startup for a little bit. This is normal operation.
Air Fuel Input Module - ECU Master - Hurricane Performance
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
Things will work right up until the point that they don't. You're trying to diagnose a problem, this needs to be confirmed.I need to check. I didn't figure it would lose power after working perfect last spring.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
I have the ECU master set up on my sled, it does not have any lights on the module like the AEM. Mine does not show any codes at all when powered up, no Sd - 24 codes...nothing. This past off season I worked with Dave to resolve this issue. When its unplugged it will flash the Sd -24 code continuous with the key on or engine running. Which is exactly where you're at with your set up. The module is not getting powered up, it will flash the code until it can start reading AFR's.
- 7K
