earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Its worth a quick once over of the entire exhaust. Any leak in the exhaust will throw off the O2 sensor. The primary impact of which is that the sensor would read the AFR as lean. (causing enrichment and poor mileage).
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
I’m my case it involved the AEM sensor. There was a bad batch of them that made it to market it took over a year to resolve with the vendor and about 800 miles on the sled some of those were with the sensor unplugged cuz I couldn’t handle looking at 14.5 on the screen. Sled runs super strong now so I don’t think there was any permanent damage. Tune went in in Jan22 and it was the following Jan that it was resolved. With lots of conversation in between The sensor never did quite and would function properly at times. It was very frustrating and impossible to dial in the clutching. I believe it was the module that was the problem not the sensor as I changed both to fix it. If it was a resent purchase I’d be on the vendor to make it right sooner than later.
Good luck
Good luck
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
If you have the flasher and the app you can select in the app if you want hr meter to read boost or afr. If you have dash flash you can monitor both at same time.I believe u can only read boost on the hr meter with the stock guage? Need dash flash to get afr
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
It should throw a code if the 02 is bad and then the tune will default to the base tune so MaxSpool 17 in my case. I dont think it could ever lean out totally.Does the closed loop turn off and default to the tune when the O2 sensor takes a crap?
Can the O2 sensor just give false readings, and if so is there a possibility for damage if it leans things out when it’s already lean and reading false values
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
And you werent getting any codes? I'm wondering if that's what's happening, its a bad 02. I dont have the AEM module.I’m my case it involved the AEM sensor. There was a bad batch of them that made it to market it took over a year to resolve with the vendor and about 800 miles on the sled some of those were with the sensor unplugged cuz I couldn’t handle looking at 14.5 on the screen. Sled runs super strong now so I don’t think there was any permanent damage. Tune went in in Jan22 and it was the following Jan that it was resolved. With lots of conversation in between The sensor never did quite and would function properly at times. It was very frustrating and impossible to dial in the clutching. I believe it was the module that was the problem not the sensor as I changed both to fix it. If it was a resent purchase I’d be on the vendor to make it right sooner than later.
Good luck
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Mine showed running lean most of the time with no codes. If you unplug sensor it will revert back to original tune without CL. And I would think your fuel mileage will be back to normal. I’d either replace module or get dash flash to monitor afr
Other than that it would be a problem with the tune
Is this a new install ?
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
I believe it was a module issue as I swapped out o2 sensors with no change
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I believe AEM sells the module and some universal wiring relatively inexpensive, it would just need to be pinned correctly.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Just reread old posts from last winter there weee other guys having the the same issue with ECU Masters https://ty4stroke.com/forums/sidewinder-trail-talk.119/And you werent getting any codes? I'm wondering if that's what's happening, its a bad 02. I dont have the AEM module.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
Last year my O2 sensor went, on Hurricane tune, and it began running super rich. My mileage went way down. Lucky to get 10mpg. There were NO CODES present, but when looking at the afr reading on the factory gauge, the numbers were all over the board. Nothing steady. Replaced the o2 sensor and back in business.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
My mother always told me the more you monkey, the more you can.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I was under the impression that if 02 sensor fails it defaults to 300 ss tune in which case mileage isnt really horrible?
Doc Harley
- Oct 17, 2016
- Here & there
I Incorporated The kiss principlesMy mother always told me the more you monkey, the more you can.
Keep. it. simple. stupid.
Works on everything in life.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
If the sensor is not reading it will go back to the default tune. If the sensor is reading but not accurate, there would be no programmatic way the tune would know without another source to go off of.I was under the impression that if 02 sensor fails it defaults to 300 ss tune in which case mileage isnt really horrible?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Closed loop won’t work untill at or over 18mph, if sensor goes bad it will mess with reading, you unplug the sensor then it reverts to the stock maps.
- 6K
- 6K
