RylanB
- Dec 4, 2019
- penhold alberta
- 2018 arctic cat king cat m9000
I've been looking at both one is over 700 one is round 450. Any insight plz?
Thank you very muchThe Hurricane kit will work fine for boosting fuel for higher horsepower. The PEFI kit works great and keeps the fuel pump basket full of fuel at all times.
I have a sidwinder ECU with the hurricane 270 high elevation flash for sale if your interested, I have the charge tubes 3 bar map sensor, strait pipe exhaust and blow off valve as will. WorkEd very well on my sled I just decided to do something different wanted more hp. So went with stage 3 Mcxpress.I've been looking at both one is over 700 one is round 450. Any insight plz?
You still have the ECU with the hurricane 270 HA flash? How much if so?I have a sidwinder ECU with the hurricane 270 high elevation flash for sale if your interested, I have the charge tubes 3 bar map sensor, strait pipe exhaust and blow off valve as will. WorkEd very well on my sled I just decided to do something different wanted more hp. So went with stage 3 Mcxpress.
I still have it but not selling for now, using it on my mcxpress kit it actually works better than there controller up to 20 psi,I have found there is no need for the 4th injector at 20 psiYou still have the ECU with the hurricane 270 HA flash? How much if so?
Gotcha! I'm about to bite the bullet, so am hunting for lower cost options first. Much appreciatedI still have it but not selling for now, using it on my mcxpress kit it actually works better than there controller up to 20 psi,I have found there is no need for the 4th injector at 20 psi
I am running the hurricane flash with the mcxpress turbo and inner cooler, the hurricane box seems to work better than the mcxpress controller system, I found I can turn the fuel pressure up 1psi and run 22 lbs boost with stock injectors no need for the 4 injector. It is a 270 flash but I put a manual boost controller on and turn the boost were ever I want it and the hurricane box controlles the afr,s just fine.How has that mcx kit been working. I was looking at that
