ronzx9
- Jan 11, 2017
- Ohio
- 2017 Sidewinder L-TX-LE, 2016 Grand Touring SE 1200
I read in the GAP instructions that leaving the flasher connected can drain the battery. I was wondering if that was accurate and if we have to pull the flasher if leaving the sled parked overnight or longer? I recently installed the setup and and went out today to finish things up and the battery was low. I wasn't sure if it was from sitting over the summer then a bunch of start/stops while working on it or a coincidence?
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Check this thread. Depends on how your flasher is connected. Short harness directly to diagnostic port = battery drain (mine is this way).
https://ty4stroke.com/threads/hurricane-td-gap-flashers-need-to-know.154431/
ronzx9
- Jan 11, 2017
- Ohio
Thank you. I was worried if I left it plugged in over night if it would drain especially up in Quebec where I do most of my riding. Sounds like that shouldn't be an issue.
WinterWolf
- Mar 25, 2017
- Connecticut
Overnight not a problem at all. Especially cuz you’re running it all day/or using it regularly.
I was told that if you are gonna let the sled sit for more than a couple weeks, without riding it..then Disconnect it to be safe. Takes only a second to disconnect and plug back in when you’re ready to go.
