y_guy
- Feb 22, 2005
There was an add for a tool that you could buy to pull hyfax off your sled. Has anyone used this and does it work or is this just a gimmick?
i think it was called the EZ Slider removal tool
BURMAD69
That tool looks like just a slide-hammer with a screw in it to attach to hyfax then hammer out, Should work ok.
Tork
That EZ Slider is one of my favorite tools
some tips in here
http://www.ty4stroke.com/viewtopic.php?t=24790
some tips in here
Len Todd
Just back them out into the track windows a bit and run the sled in reverse. The slides come right off.
y_guy
- Feb 22, 2005
you know, i never understood that. How does one turn the sled in reverse with a slider hanging out the track window.
Yakuza
- Burlingame, California
- See sig
You peel it off like a banana.
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
y_guy said:you know, i never understood that. How does one turn the sled in reverse with a slider hanging out the track window.
Two similar concepts that basically do the same thing:
When you put the sled in reverse and give it a little throttle, the track window will eventually press against the hyfax, deform it, and bend it off of the grooves on the rail.
What I do (I don't have reverse) is use a chisle & hammer. I strike the hyfax so that it slides backwards through the track window about a foot. I then grab it with my hands and pull it towards me and towards the front of the sled at the same time. It'll stay in the track window and the track will travel in reverse as I continue to pull on the hyfax until it comes completely off.
As long as the hyfax isn't frozen it is usually pliable enough to bend off of the rail without snapping in half. I've done that before when they were too cold. If that happens then I just use the hammer and chisle to complete the job.
My cousin actually welded an old pair of vice grips to a slide hammer and that works fantastic for us.
Woody said:My cousin actually welded an old pair of vice grips to a slide hammer and that works fantastic for us.
That is an excellent idea.
y_guy
- Feb 22, 2005
i have been doing it the old way for years, using a wood stake and a hammer to pound them out the back. but i have 3 sleds to do and as we know snow conditions in Wisc and hyfax longevity on yamaha's isn't always the best. I dread having to do it so much. I am hoping the EZ Slider works as intended. Nothing worse then laying out on a cold garage floor wrestling hyfax on 3 sleds. It burns a whole day of riding.
dmaxx
- Apr 5, 2006
- sw Michigan
- 2015 Viper RTX, 2012 Apex XTX, 2010 Vector LTX, 2000 AC Z-370..fast
- White Pigeon, MI
I have 3 EZ Sliders available brand new for $55 ea., they retail for $69.
Shivesy
I read on here about the banana peel trick. Try it with the track lifted off the ground 3 or 4 inches. I don't know why you would need a tool when they can be removed so easily. Give it a try and you will see. Tap one side hyfax out the window no more than a inch and put it in reverse and give it just a LITTLE gas and it will be off in a second. I was amazed! Gotta love this site for tips like this one.
blue er
my dealer charges a half hour labor ($30) to change sliders since there only 10 minutes up the road there doing it, save my back the pain from bending
Shaf
Hyfax
I use a 10$ dent puller i picked it up at the bargain bin at Napa , its a piece of cake just drill a pilot hole in the back of the hyfax sidewall then thread the screw from the puller in and bada bing its done,i lube up the track window and that seems too help also.
Make sure to back the track off before starting.
- 9K
