HYFAX replacement
I normally am able to pull them out thru the windows....haven't replaced them on my warrior yet, so not sure if they will fit.
I have read where guys will widen a single window by carefully cutting it to allow the hyfax to fit thru.
They were tight on my old vmax's, but with a bit of effort and a little soap, they would fit thru the windows.
I was told that if you have the Ripsaw track, Then you have to drop the skid because the hifax is bigger than the windows. I havn't checked for myself yet though.
hyfax
I don't know anything about wide vs. narrow hyfax, but when I replace mine I just slide them through the windows. The worst part of it is the screws. Be very careful when reinstalling them, because they strip easily and having a tap on hand is a must (in case you strip them, you will have to re-tap the hole.) The hyfax I am using are ones the dealer gives me when I ask them for new ones for an '05 RX-1. One thing I have learned to do also is to lube the hyfax before sliding them on. I actually just use some grease or silicone on the hyfax and put some on the rail itself. This also helps when I go to take them off. Some say it's a lot easier to loosen the track too, but I have found you don't necessarily have to.
Re: hyfax
YUP!!
I tip my sled on its side, take out the screw, take a big screw driver and drive the slide back until its hitting the track, I line it up with a window (you have to twist it a little because it is a tight fit but it will fit out) then drive the slide back until I can get a pair of vise grips on it, Then I clamp the vise grips on the piece sticking out and pull it off.
I then warm the rail with a torch and spray a little bit of wd-40 in the new slide and on the rail. Then slide on the new hifax and screw it in.
I dont loosen my track or anything its really pretty easy (30-45 minute job)
i have to agree with shanks! it does barely fit through the window , takes a little bit of persuasion with a screw driver but they will go!
thru the hole is the best way imo.take screw out,then at back,wedge a flat screw driver between slide and rail to pop it out about 3-4 inches,line it up in the hole manually then start sled,pop in reverse and gently turn track,it will fall on the floor without a sweat.done it last week and it was a breeze.make sure to drill the new hyfax hole a tad bigger,will help when reinstalling it
Sweet... it fit through, and I'm ready for the new ones, but I also noticed, that I have the inside rear wheel bearing was shot... so I need to replace that.... is there any reason that they don't run a 4th wheel? I think I'm going to buy 2 wheels and just cut the spacers accordingly, and run a fourth... Hopefully be back in buisness soon!!
on both my 03 and my 05 I lay the machine on one side usually the right, undo the keeper screws, using a large screw driver and hammer drive them back about 2 inches. I stick the large screw driver through the track window (from the front) between the hyfax and the rail, prop the foot rail on a block to lift the track off the ground. Fire her up in forward & touch the throttle to engage the clutch. I can change both in under 10 min. I also put a bit of windex or soap on the new one to help ease sliding it into place.
Re: hyfax
YUP!!
I dont loosen my track or anything its really pretty easy (30-45 minute job)[/quote]
Funny... EXACTLY HOW I DO IT...
But they only diff. is now I have an overhead hook and I use my come-along as a jack...
YES..BE CAREFUL WITH THE SCREW!!!! WHAT A PAIN IF YOU CROSS THEM UP!!!!!!!!!!!!!!!! :o|
