aftica24
When going to change hyfax I noticed one srew is just flush with hyfax and when removed it looks like the threaded hole is messed thus it did not go in all the way.
Any tricks out there or ideas? I assume as long as it is flush it will not cause a problem?
Thanks!!!
Thanks!!!
grader
if it goes in and is flush then no problem, if not then drill it through an use a nylock nut to hold it.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
grader said:if it goes in and is flush then no problem, if not then drill it through an use a nylock nut to hold it.
x2 best way to do it, just like a cat.
aftica24
Thanks for the help
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
MadMax
I simply put in a shorter screw and made sure it seated good........ Done that 4 years ago.. no problems. MM.aftica24 said:When going to change hyfax I noticed one srew is just flush with hyfax and when removed it looks like the threaded hole is messed thus it did not go in all the way.
Thanks!!!
new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
Rockerdans method better than stock .
