breakinbarrs
- Dec 31, 2007
- Not North Enough,Ashburnham MA
Anyone using the Hygear Dual Rate Spring. Any input would help. I am trying to decied between that and big boy.
ROCKRTX
I did the hygear set-up on my KYB mono and very happy with it.All adjustment you need + ad oil reservoir so the shock will not fade + dual spring to prevent bottoming.Now my mono shine!
Can ride all day long with my friend 136" ZX2.
Rock
Rock
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
I pulled the trigger on their full setup. Dual rate on the EC Ohlins, dual rates on the front GYTR with hi/low resi. Made for a wonderful difference. I'll be sending all 3 to Ross in the off season for rebuilds and have the fronts valved a little softer. While a little pricy, he knows his stuff.
I'm pleased with mine.
hygear
Hygear, just do it!
You really can't compare a single rate spring against what Hygear does. That would be like comparing apples to oranges. The twisted springs and hy lo rezi's give you the ability to get the suspension dialed in for anything from stutters to big whoops.....This is my 2nd time around with the trail pro set up, and it is fantastic. Would spend the money again, in a minute. Just a few adjustments got me exactly where I wanted to be for a wide range of conditions.
Mike
Hygear, just do it!
Mike
