feysfunworld
- Dec 20, 2008
has anyone just ordered the dual spring and put it on the shock themselves if so how did it work?
feysfunworld
- Dec 20, 2008
no one
feysfunworld said:has anyone just ordered the dual spring and put it on the shock themselves if so how did it work?
I did the dual rate rear and the triple rate fronts at the same time and it made a huge improvement. I would recommend just the fronts first if you can't afford all of them at the same time but all of them together really makes the sled handle a lot better which I think is mostly because it lowers the front end some. Riding my sled with the springs and USI skis then hopping onto my friends completely stock Nytro through the same sections of trail confirmed an amazing improvement.
larrypolaris
Last season I only ran the front ski triple rate springs with stock FR suspension spring. This season I installed the dual rate suspension spring. I first set it up according to Hygear specs of 5mm set in. The sled road great, really smooth on the stutter bumps, but it seemed to add more ski pressure. I turned in the dual rate spring 20 quarter turns. The sled still rides great and a bit less ski pressure.
The spring package is well worth it. Really helped with the handling of the sled and bump capability.
bottlerocket
I put front and rear center on with Goodwin revalve and very happy with the results. Never tried without revavle but I read on here that guys did just springs with good feedback.
