Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Who has put the Hygear torsion spring spacer on their Nytro XTX? Does it work well? I was going to order one but I'm wonder how long it takes to install? Is it worth it? Can I put the spacer in with out taking out the skid? There's just no installation instructions for the Nytro so I have no idea if it's a 30 minute job or 6 hour job. Thanks
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Plenty of threads on it for info, search is your friend.
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
Yeah skid will come out ,or at the very least be dropped from tunnel in rear.
i did it while i had the skid out on my xtx but you only need to loosen the track tension, unload the springs and unbolt the rear shaft to get them on once you remove the stock ones.
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Did it make a big difference on the sled?i did it while i had the skid out on my xtx but you only need to loosen the track tension, unload the springs and unbolt the rear shaft to get them on once you remove the stock ones.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I did it on my XTX and I think it helps make it smoother (doesn't bind) but I did it on the wife's Phaser and it it made a ton of difference
it was binding/sticking a bit before i put them on so it did help smooth it out.
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Did you instal it with the skid under the sled or did you take the skid out?I did it on my XTX and I think it helps make it smoother (doesn't bind) but I did it on the wife's Phaser and it it made a ton of difference
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
I did it with the skid out when i was servicing it. Which i do every fall pre season. But it can be done quickly by just dropping the back. Not a big deal. Shouldnt take much more than an hour. I did not notice a significant amount of difference but i like the idea of the spacer being in there. Go for it. It will be a great learning experience .
canoehead
- Jan 14, 2011
- NE, Alberta
I just dropped the rear and left the front skid bolts inDid you instal it with the skid under the sled or did you take the skid out?
