RX-Dave
- Nov 14, 2004
I am trying to take my chaincase off for a track swap, and need to know the wrench size for the nut holding on the top gear on my 05-rx-1ER so I can go buy the wrench.
Please help
Dave
Please help
Dave
A big cresent wrench work's perfect.
36mm
RX-Dave
- Nov 14, 2004
Ok
Ususally them things are tight, and I hate adjust-a-wrench
lol
Thanks Pro, I will pick one up at sears
lol
I doubt pimp and queers will have a 36mm that deep. I have used the buddy dealers socket, its deep. There must close to 4" sticking out. If you find one there that works, can you post the part number. thanks
snowy1
used a crescent wrench on all mine no problems
4bangdan
- Sep 8, 2005
- Fort Kent, Maine
- 2004 yamaha rx1 2015 yamaha apex xtx
checked walmart, seems benchtop dont make a 36mm lol
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
How do you remove that nut without the sled moving?
Put a pry bar in the track window against the ground for leverageHow do you remove that nut without the sled moving?
RobX-1
- Coldwater, OH
I have a 36mm deep well socket like the one in this post:
https://ty4stroke.com/threads/yamaha-chain-case-top-gear-36mm-socket.150272/#post-1392008
that I use for the nut but to prevent the jack shaft and drive train from moving as I loosen the nut, I use a large crescent wrench on the drive axle since it is hexagon and not just a round shaft.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
You all gonna laugh at this one!!
When I changed the track on my 03 I used a pipe wrench.
