Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I have a 2023 Yamaha Sidewinder LTX GT EP and I need a Windshield for it, and it's not available? How is that possible for a machine that's only 3 years old, and I paid $20K for it! Anyone know where I can get one? No one seems to have one!
Windshield Comp
SMA-8LR96-30-SM
Windshield Comp
SMA-8LR96-30-SM
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Are you looking for a higher windshield for your sled ? I think you need to go to a Cat Dealer and they should be able to find one that will work! Iam pretty sure thats what I did !
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
The mid height Cat wind shield doesn't shake like the Yamaha one either. It is secured on the side.
Bob Miller
- Apr 19, 2003
- New Milford CT
Thanks, I'll check!Are you looking for a higher windshield for your sled ? I think you need to go to a Cat Dealer and they should be able to find one that will work! Iam pretty sure thats what I did !
Bob Miller
- Apr 19, 2003
- New Milford CT
Bob Miller
- Apr 19, 2003
- New Milford CT
Sounds good, I'll look into getting one of those!
Bob Miller
- Apr 19, 2003
- New Milford CT
Will this one fit the 2023 Sidewinder LTX GT EP? https://www.denniskirk.com/powermadd-cobra/clear-w-black-17-in-mid-windshield.p234824.prd/234824.sku
2 Questions
Price:$180.00
PowerMadd by Cobra
- Part #:
234824 - Mfg Part #:
14530 - Add'l OEM/Ref Numbers
2 Questions
Price:$180.00
RobX-1
- Coldwater, OH
It states it does...
Bob Miller
- Apr 19, 2003
- New Milford CT
Bob Miller
- Apr 19, 2003
- New Milford CT
Thanks, I ordered it!
I use that one. I assume you're referring to part number 7606-458The mid height Cat wind shield doesn't shake like the Yamaha one either. It is secured on the side.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Yes, and if you do it right, the hole you need to drill for the lower edge of the windshield will line up perfectly with the hole in th end of the headlamp assembly making it super stable.I use that one. I assume you're referring to part number 7606-458
nosnonosno
- Mar 11, 2026
- ILLINOIS
- tcat
Can the hood be disassembled to install the u nut and screw arctic cat suggests or do u just have to guess from the outside where to drill a hole in a $20,000 machine. Or has anybody used a christmas tree fastener? Any suggestions appreciated.Yes, and if you do it right, the hole you need to drill for the lower edge of the windshield will line up perfectly with the hole in th end of the headlamp assembly making it super stable.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
They supply a fastener, I didnt use a nut. I guess you could use a rubber well nut, but the plastic one works for me.
Bob Miller
- Apr 19, 2003
- New Milford CT
Thanks for all the feedback!
