Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
What are the ski bolts doing? Stuck? Slopped out? Cant give you a cure if i dont know the problem!!
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
nicgagnon said:What's the cure for ths skis bolts in spindell?
Are you talking about the ski bolt bushing? Ulmer sells new bushings for that too, tightens them up just like the a-arm bushings.
nicgagnon
Sorry, the problem still the same. Lot of play. I want tigher drive. I hope, I'm clear. French canadian ;o)
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Ulmer bushings are the fix, it's just that removing the old ones are beotch!!
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
canoehead said:Ulmer bushings are the fix, it's just that removing the old ones are beotch!!
The plastic one? Those are easy to remove, just break them. Try to take out the ulmer ones, now those are a pain in arse to take out.
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
Removing the factory ski bolt bushings is a pain in the arse. Look for the seam in them, the try to stick a small screwdriver or thin chisel between the bushing and the spindle. Eventually you can pry up the entire bushing on one side of the seam and pull it out with a needle nose pliers. Installing news ones, smaller threaded rod with some washers and a little extra caution. Piece of cake!!
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Nevermind my last post, I was thinking the a arm bushings for some reason
And yes those spindle bushings are a pain to get out for sure! I ended up using a hacksaw blade to cut them, then use a screwdriver to pop them out.
And yes those spindle bushings are a pain to get out for sure! I ended up using a hacksaw blade to cut them, then use a screwdriver to pop them out.clatla
Scott at OFT has some bushings for the bottom of the spindles. I got a set from him. They really tightened up my front end.
