pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Hey guys, trying to remove the steering post to change airbox, having troubles getting the linkage arm off the bottom of the steering post. Removed the nut with safety pin and it will not release. Do you need a a special ball joint fork to get it apart? I tried leaving the nut on and hit it with a hammer with no luck.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Thread a nut on flush with end of stud and give it wack with a hammer. It's a taper fit so just needs a little force to free it up.
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
I tried that, looks like i have to hit it harder lol, maybe a little heat would help?Thread a nut on flush with end of stud and give it wack with a hammer. It's a taper fit so just needs a little force to free it up.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Whooa! Go easy.......Putting an oft relocate on a few years ago I did exactly what was written above and it did not work out in my favour. Tore the threads off the tie rod and made a mess of things.
Heat it up with a heat gun, use a pickle fork, small pry bar, or big slotted screw driver. When its screaming hot, get the driver in behind the ball join and pry down. Then tap on the nut. Don't wack it.
It should just fall out of place.
Hope that helps. this is coming from a guy who f'ed a perfectly good weekend of riding because of that pressure fitting.
MS
MS
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
I had an old wrench laying around and I just ground the fork end down a little bit and made my own ball joint tool. Worked great and didn't need to hit anything with a hammer.
Dr. FeeLGooD
That's an awesome idea! I used a pickle fork but it was a little too big. I will use your method next time.
Deeppow16
- Oct 19, 2015
Yeah I saw it on some automotive forum somewhere and figured I'd give it a try and it seems to work pretty good. Plus I can still use the wrench.That's an awesome idea! I used a pickle fork but it was a little too big. I will use your method next time.
Michigandir
- Nov 28, 2014
- Michigan
- 2013 Yamaha nytro rtx
Just did mine a few weeks ago. I used 2 screwdrivers. IT WAS TIGHT! but it popped off.
- 28K
