If chain case is off and speedo bearing is out the only thing left to hold it is the track. Just lift the track and bunch it up under the axle a bit to take the stress off the driveshaft. Or are you saying that you took the guts out of the chain case but the shaft is still in the bearing in the case?
If chaincase is off, you can pull either way. If not you have to pull towards clutch side.
