Where do you find the diode on the 05 Grizz mine wont start wqith the starter and its damm hard to pull start, I tested the system and it points to the diode but I cant find it.
I dont know if they have made many changes to the 05 machines from the 02, but my manual is showing the diode is under the odometer display. Its a small box that plugs into the end of wires with terminals. I wish I had the capability to put picture but pictures not to great. There are alot of other switches recommended to check first. I hope this helps
