mooseflyer
Hi all,
My Venture squeals when I'm sitting at idle, which I assume is the belt. I did a search, and came up with some info. However, most of the info related to a squeal problem with a NEW belt, and the advise was to change shims/washers or ride a few hundred miles and let the problem fix itself.
My situation is slightly different, in that I DON'T have a new belt - I haven't touched the clutch/belt since last year, and I didn't have the problem last year. Why should this pop up now?
Following advice I found while searching, I plan to rub the inside faces of the secondary with a scotch brite pad and wash the belt with some soapy water and give it a good rinse. Any other area I should look at? Again, this is NOT a new belt (it has 1200 miles on it). Thanks!
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Also wash/clean the belt to get any dust off it as well. Here are some other thoughts:
http://www.ty4stroke.com/viewtopic.php? ... =wash+belt
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
When is the last time you took your secondary apart? The sliders inside the secondary could be excessively worn, especially if you've never replaced them on your 06 Venture. The spring could be tired as well.
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
Take the one shim washer out of each of the three screws on the back of the secondary... Your squeel will not come back nor will you notice a performance difference... Both my ventures were quiet out of the box then developed the squeel after a few miles then went away after 1500...
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
I have the same squeal on my vector! I plan to remove shims from the screws on the back of the secondary also. It even creeps forward a little so I think my belt is a little too high in the secondary which is causing this. Funny thing I don't remember it being this way when I put it away last year.
tuner
remove the shims. I did, well the the dealer did, and fixed the problem.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Pulled the shims problem solved!!
mooseflyer
Awesome, thanks gents. Will try the above suggestions.
RSVECTORFREAK said:I have the same squeal on my vector! I plan to remove shims from the screws on the back of the secondary also. It even creeps forward a little so I think my belt is a little too high in the secondary which is causing this. Funny thing I don't remember it being this way when I put it away last year.
If it is creeping forward it may be a busted spring. The last sled that I had that creeped forward the spring was broke.
If it is creeping forward it may be a busted spring. The last sled that I had that creeped forward the spring was broke. It would only creep forward on the pavement.
