Idler agjustment ????
blackhawk
Nova Scotia, Canada
I adjusted my idler rpm higher for engaement for racing. I noticed I lost 500rpm. Is it because of changing the idle rmp to high or may it be another issue? What is the stock idle rpm suppose to be and how many turns on the nob would that be?
I assume your talking about loosing 500 RPM's at WOT, if so, the idle adjustment won't have any affect with that issue.
If you want to change your clutch engagement RPM you can not do that with the idle adjustment. You will need to make changes to your primary clutch.
Changing your idle speed should have no effect on your engagement rpm or your shift rpm.
