idle screw adjustments
apex4
Quispamsis nb
ok guys...i cleaned out my iav... and removed my idle screw, all the way out...
question: how many treads (turns) after the treads engage as a set point..then i can go from there...and someone told me this is just for cold idle???? any comments would be grt!
Your goal is to set idle screw so that your idle RPM is as per manual. My Venture idles at around 1400 RPM (as per book). Turn your throttle screw in or out until the specified RPM is obtained
- Turning in=Idle speed increase.
- Turning out=Idle speed decrease
Hope this helps.
