looking to replace the wheels on an 04 rx-1. bought a couple kimpex wheels and am not impressed by the quality. the front idlers pn#04-116-96p have a much smaller bearing size than stock and as it turns out the inner brg bore diameter is about 1mm to small, so it doesent work. in addition the stock plastic spacer bushings dont work with these wheels.
the rear 7 inch wheels pn#04-116-98 fit well, are similar in quality to the stockers. i will run em till they quit and report my findings.
i blew the sides out of the original wheels right by the snap ring. so i am looking to upgrade to a stronger wheel. can anyone recommend a suitable replacement that is stronger than stock and fits well. will consider a reasonably priced aluminum.
