joe d
Im thinking of adding an excell wheel kit to my 07 RTX. Are u guys changing the rear inside wheels also, or is this not necessary? Also what hyfax is everyone running now? Figured I would change those while changing out my idlers.
If changing to this for extended hyfax wear, I would replace ALL 5.35 wheels.
sherlock29
Just remember... when going to a taller wheel, you can install outside wheels with a 6205 bearing. but the 2 inner wheels MUST have 6005 bearings or you will have to mod the bearing collar... this is for the 07-09 RTX sleds... mono do nat have this issue.
apex55
Inside wheels need to be moved with the mono to keep them in the center of the drive lugs. It was roughly 1mm needed to be taken off the wheel mount. Bigger wheels did the trick for the hyfax wear.
553-610 YAMAHA RC UHMW HYFAX DK BLUE
04-053-3 PRO IDLER WHEEL BLUE (all 6 wheels)
Both from Shadetree Power Sports.
joe d
Does Excel make a whole kit for this? If not, who does or who is just as good as the excel wheels?
