if you have the time
yamahajunkie
michigan
wondering if anyone has some time to check play and noise on the track to chain to secondary? just spin track while on the clutch side either way, until the secondary moves a little. then back and forth. mine sounds alittle weird. deflextion is set proper. runs fine. just replaced the highfax. wonder if they all have noise like this. thanks junkie
Its different with and without reverse. It moves a LOT. If I spin the secondary, at least an INCH on the outside edge.
Check your chain tension (loosen locknut and tighten bolt finger tight, then retighten locknut). Also would be a good idea to INSPECT the chain (do this annually) - remove chaincase cover and look at every link, measure free length, make sure its good.
Most of the play is between the drivers and the track. Jay
thanks for the reply's! just going over with the fine tooth comb and noticed this. check the viper and srx, not as much play. warrior has reverse though. i removed and inspected chain/gears everything is everything. thanks again, just thought i'd ask. :rocks:
