Ignition module on 2012 apex
It may work if you swap connectors. It is not a direct plug-in item.
It's plugged in but not sure if there is anyway to tell if it is actually working
With the engine idling and your computer plugged in, change the ignition timing at the idle speed and send Send Map and you should hear the engine change "tones" when it changes.
Alright I will try that thanks.
