ust421
Ok folks just picked my 09 MCX nytro up from the shop last night. I started it in the shop it started and ran just fine. Trailered it home and went to start it this morning which it was about 2 above. And as soon as I turned the key just to the ON position the starter started to turn over and then it would stop and when I hit to the key to start it i would just get a click click. So I grabbed the charger and started it and was given a error code of 46 which is power supply. Took it for a quick spin and man all I can say is WOW.. Parked it in the heated shop and started it after about a half hour and the code went away. It started fine on its own then. Went back out 4 hours later and same sh*t with the starter kicking in when turning the key on and battery was about dead again. I am just wondering where I should even start to look.
ust421
Has anyone had there starter kick in with just turning the key to the ON position?
towerrigger
Did they wire in any new gauges? I had some weird things happening when I tried to wire power to the gauges from the ignition wires.
ust421
Yes a boost gauge and it did look like they did wire it into the ignition plug.
ust421
Where are people wiring in there boost gauge at?
ust421
The problem was that the boost gauge was wired into the ignition plug this is what was cuasing it to turn over with the key just turned to the ON position. I am thinking of wiring the boost gauge into the dc plug does anyone think that will be a problem?
YamaMTX
- Feb 7, 2009
- crosslake MN
- 2009 Yamaha nytro and polaris 600 rush
For you it will work just fine! I promise Jk buddy
