I was trying to start my 06 apex and no luck. It turns over and is def. getting fuel into the fuel rail(confirmed it) but no fuel getting past the injectors into the cylinders. What could be preventing the injectors from opening or what powers the injectors to open them? Is there any fuses or other equipment that could cause this?
MT.man
Check the gauges and see if it shows any codes . Last year my sled did the same thing and I found that I had a engine code 12 and the stator needed to be replaced.
FLYBYU
Put a charger on your battery. It'll crank all day but no fire= Low Battery. Let it charge overnight. Try this first
Thanks for the reply. Will check codes. Battery is not charging. Will replace battery and check again. Thanks
FLYBYU
I've seen it many times where you'll put a battery booster on it and it'll turn quickly but it still won't start. Battery doesn't have the amps to run everything. Your battery probably is shot.
blue er
went trough this last year turned out it was corroded ground blocks
Took off all grounds and cleaned them. They were not dirty. Have new battery, charging now. Will check in the morning.
FLYBYU
Keep us informed.
