favarcat
Spoked Style Plastic Idler Bogey Wheel, Black
SMA-8FP38-01-BK
Been running these this year for 2500 miles and they are perfect.
SMA-8FP38-01-BK
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
rx1pat said:I see the spoked wheel in the catalog, but don't see black as an option. However, I notice in the posted pictures everone has black wheels. In the catalog they show blue, red, silver and grey available. Does anybody have the correct part number for the yamaha black spoked wheel?
i thought the same, black is not shown in the catalog but code "BK" is valid on the dealers computer when ordering.
ROCKERDAN said:we all know the original 06 wheels and some 07 wheels were falling apart the first ride out,less then 50 miles....they would WARP or simply chunk apart...
so I replaced all mine with the spoked wheels...the outer spoked wheels now still look perfect with near 4000 miles on them,while the inner ones have started to slightly chunk up(not too bad) at 4000 miles....
the inner wheels wont EVER last as LONG as outer wheels when you stud inside only....as most all of us have done.....if you stud outside the rails IMO all wheels will last similarly.
the thinner sliders last longer and run higher speeds on radar....simply due to the fact they allow more snow thru the windows,and they run MUCH COOLER then the stock wide sliders....this is what I have experienced....but do what you like.
once again,yammie wheels and skids are some of the worst for slider and wheel wear when compared to the other 3 manufacturers...
But if you add two wheel kits and thin slides...IMO you may NEVER have to change sliders.
Dan
Dan do you have a part # for the slides and do they fit through the track windows?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
121" graphite slides(narrow)
SMA-8CM92-70-HP
Dan
SMA-8CM92-70-HP
Dan
- 19K
