snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I have an 08 nytro and I had my dealer install an ulmer clutch kit and tonight I installed a brand new belt and took it around the yard a few times. When I came to a stop I had a very bad belt squeel. What needs to be done to fix this? thanks for any help you have.
sgilbert
smaller shims on back of secondary
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
Yup shim the belt
snopro442
- Dec 10, 2007
- neenah wi.
so I need to remove the secondary and have the dealer install the shims to open up the secondary to drop the belt down a little? also, whats the best way to remove the bet because it a real pain in the #*$&@ getting it off. thanks again.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
You remove the shims from the three bolts on the back of the secondary which lowers the belt into the secondary. This is a simple job so there's no need to take it to a dealer. If the belt is to low with the shims removed then different thickness shims are available.
Video for belt removal/installation: Belt removal
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
as far as it being a pain to remove the belt:
http://www.richmotorsports.com/store/ya ... -tool.html
bradb
It is possible to end up with the wrong belt, I got a brand new ultima XS from a dealer the cardboard package it came in was the right number but the belt was a different number, it went on harder then normal and squeelled bad and creeped a little, measured the belt and it was almost 1/2" shorter then it was suppose tobe, so i took it back, got right one, worked perfect
snopro442
- Dec 10, 2007
- neenah wi.
what should be the correct part number for the belt for the 2008 nytro fx 121?
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
8DN-17641-01-00
snopro442
- Dec 10, 2007
- neenah wi.
great, thanks for the info.
nytrolabrador
.snopro442 said:what should be the correct part number for the belt for the 2008 nytro fx 121?
8dn176410100
