installing air intake system on rx1
rx-1mountain
Makkovik, NL
i am having trouble putting on my air intake system on my rx1 mtn. in other words the beeder. first i thought i had it on then i forgot to put on that little holes at the bottom of the breeder. would that cause anything if that was left unhooked from the breeder? now for the main question. i recently just installed the updated float bowls over the weekend and i took the carbs off of the carb boots attached to the motor. now when installing the carbs back on my sled. i have put them on the boots attached to the motor good. and tightened them up. then put the breeder on and i can only get the 2 carb boots on the left side of the breeder to work. i have tried this a few times and it seems like its bringin up on the 3rd carb boot towards the right side. it seems so hard to get the breeder on my sled. i have never had this problem before. can anyone tell me what to do. also this may be a stupid question but i am only new at this.
thanks
Make sure the clamps are good and loose, get the bottom on all four carbs first then tilt up and over the tops. I get it started then just push forward and work it left and right till they slide all the way on. You can try a little WD40 on the rubber also to help it slide on easier. Must be an 03 : )
haha ... ya i got them on after thanks. also, what is that holes there for at the bottom of the breeder?
the small hose is just a condensate drain and does not matter if its attached.the larger hose is from the crankcase near the clutch side and should be hooked back into airbox. spray wd40 on outside of carbs and inside of boots to help with re-assembly.
