Wot1
Took my newly acquired 12 nytro mcx 270 out for its first ride and it's popping around 7500-8500 rpm (10 lbs boost). I suspect low fuel pressure, it will pull hard for split second and then fall on its face and start popping. Anyway, it has braided SS fuel lines, I cannot find a "T" fitting to install a fuel pressure gauge in between the fuel rail and the regulator. Anybody install one before? Any tips? Thanks
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Does the regulator not have a port for a fuel pressure gauge? I dont know what MCX uses for fueling, but stock there is no regulator. Returnless system
