thebest
No problem with my Ipad at -40celcius with the gap set-up
Lusemeat924
- Jan 1, 2016
- Drumbo, Ontario
- 2018 Yamaha Sidewinder 137 XTX SE
Turnerrd. Do you have yours set up like TD Ben's? I believe enough heat comes through the hole where the gauge(Speedo) used to be to keep some warmth on whatever's mounted there. I'm just not a big fan of the position of the gauge there.
No I didn't do the TD relocate kit. Did my own thing but looks very similar. I can see how the TD set up can keep it warmer the way the iPad is mounted closer to the rising heat,,,,, that being said,,,, it looks like some kind of heater pad may be best option.
eBay was many options of 12V thin heater element pads, Im going to scan through a few and see what my options are.
lilrez
- Feb 7, 2016
- Near Ottawa
lilrez
- Feb 7, 2016
- Near Ottawa
Can you add speakers, perhaps a detonation alarm lol
Turnerrd
- Jan 12, 2017
- Ohio
- Sidewinder LTX-LE
Yes just like Bens. Works well.
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- SIDEWINDER L‑TX LE 50TH
- Green Lake Wi
This will not work as it does not put out enough heat. I tried it don’t waist you money.I'm planning on sliding a thin heat pad between the case and the back of my Galaxy Tab. View attachment 135495 $20 on ebay
- 7K
- 11K
