FLYBYU
Just wondering this. Can't seem to get it any higher than this. Pulled timing, Pulled fuel, Pulled injection timing. New plugs.
If it starting well, idling smooth, and transitioning well to throttle inputs I don't concern myself much with what the AF reading is.
I'd be fine seeing your numbers on one of my sleds if I was happy with the above...
FLYBYU
All the above are good. It pretty much stays in 12's whole range.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Mine idles best at 12.5 - 13:1, that what Apex engines want... very happy there.
Let it be...
Let it be...
FLYBYU
We had to pull timing to 10 to get it there. It was at 18. I've always tried to get to 14 on other setups. Obviously as you my lambda time has ran out.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
I am running 18 to 20 deg advance at idle, with a little more (21-22) at RPM just below to push a steady idle RPM. I also run a slightly higher idle, 1800-2000 rpm
What is your fuel pressure at idle?
FLYBYU
mbarryracing said:I am running 18 to 20 deg advance at idle, with a little more (21-22) at RPM just below to push a steady idle RPM. I also run a slightly higher idle, 1800-2000 rpm
I sent you a p.m. and an email. We were running 18 on advance but it the rpm wasn't steady and afr was terrible. I'm running same idle. Fuel pressure is 40 psi.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
That is what mine idles at as well. Any higher and it will bog when getting into the throttle. At a 12:1 idle she is crisp and clean everywhere with no bogs.
- 7K
