Takk skal du ha
I also found one track on tracks usa... But can i use 16" wide tracks to?
Can I use a 16" wide track???
jolu
Going with more than 1,75" w 9 tooth?
Hi!
Is there ANY chance of succeding with the combination of 2" lugs, 9 tooth drivers and off course grinding/removing the stud protectors?
Plans are 151x2x16.
//Jonas
Hi!
Plans are 151x2x16.
//Jonas
08NitroRTX
IMO a 2" lug track will contact the transision area where the front of the tunnel meets the heat exchanger. (removing tunnel/heat exch. protectors makes no difference here) Now I am running different drivers than stock (9 tooth 2.86 pitch) so it may be close with the stock drivers But I don't think a 2 inch track will fit with stock drivers. Since you are changing drivers it will be very tight in this area.
Yes a 16" track can fit ... BUT ... Trimming was required but my 137x1.75x16 track was actually 16.25" wide. and I ground down a few rivits and 'worked' a few places to get it in. IF one were to look at my wife's TnT with a 120x1.75x16 track it is just as close or closer than the FX Nytro.
Also I 'notched' each lug so I could keep my protectors IF I elect to stud this 1.75 track.
Even if your 2" track touches about 1.5 hours with a sharp utility knife you can trim each lug instead of taking a hit and losing money having to get another track.
Good luck. Where there is a will there IS a way!
yammi4ever
I have removed my protectors and looks like the2" will fit fine with 9 tooth drivers. By my tape measure i would say there is 1/2" room at the tightest point, maybe a little more.
It better work, I have a 2" on the floor ready to put in LOL
