Is it possible to fit nytro clickers?
gumbellion
Northern Ontario
I have been in a real bind lately trying to find reasonably priced shocks to replace mine to finish the season since I broke a shock shaft a couple weeks ago.
I have the oppourtunity to get nytro clickers off a 2012 but know they are 17.5 or so eye to eye, making them 1 larger than the apex that will also fit.
Is it possible to fit these on my phazer to get through the season without modifications? I know if it is possible they would handle different but really just wan to get my sled moving again.
Have you tried to see if someone like Peak Velocity or Shocktech in ontario has used shocks that they can sell you?
I needed some skid shocks for my fathers sled and was not going to pay the cat price for them, I was able to buy some used shocks from Peak Velocity that he rebuilt.
your looking for 15.5-16" shocks Ideally, Polaris trailing arm sleds with the Xtra 10 skid ran 15.5-16" shocks up front also if that helps you find a set quickly.
You can use them. Just set them up a little softer than nuetral on rebound and dampening
5 clicks comp, 9 clicks rebound.
well i decided to risk it as there was a local set of clickers for cheap. Turns out the lower mount is wider than on the phazer shock. Off to get them machined monday I guess
