IH8CROWS
sgauthier
do you have a pic with the belt on to see how high it's sitting in the secondary?
PowderFalcon
Pinnin' it!
What are the arrows pointing to?? Are your clutch sheaves damaged? If you are wondering about belt wear, measure the width... the spec is in your manual.
Looks normal.
IH8CROWS
The arrows are pointing to what's left of the marker lines I drew on them.
Was wanting to know if what's left is showing my shift out is good or not.
Thanks. Steiner !
Thanks. Steiner !
ranger1
If you are riding in normal snow conditions that looks about right. If you run it on ice road type conditions the belt will rub out more of your marker lines as it will shift out more. They never shift all the way in normal conditions
Unless you have your primary cut for OD the belt will stay about .75" from the top.
- 7K
