Is the transfer rod from a 06 rage the same as an 07 Apex?
Apex18
Atikokan, Ontario
I have a 07 Apex GT, and my dad has a 06 Rage. For some reason i can not adjust my transfer rode, it is just tight and will not turn, so i am just going to switch it with my dad's 2006 rage transfer rod becasue he never adjusts his. Are these the same size rods, they look the same? He never adjusts his so we are just goign to switch out. Mine is stuck in the stock setting so that will work for him, but i want to be able to set mine to MAX so i can pull some huge weelies. Thanks, Jord.
transfer rod
your transfer rod is probably just supper tight.thet way over tighten them from the factory.
Put a punch or chisel on it and give it a sudden rap, it will brake loose.
transfer rod
just take it out and try it, mine broke and had to ride for 500 miles and what a blass, and could take off hard without a wheely by leaning over bars, or pull a 2 foot wheely at 50mph
ckm
