sd5500
I have Slydogs and the studs on the skegs are off a little bit. I can't get em on. 2 studs will go in but the other 2 seem to be off by about a 1/8". Also, 1 skeg has a stud that is off center. It took almost 3 weeks to get these and I can't even get em on.
With regards to the shims Scott sent me; do I screw them into the bumber or do I use glue or both? Appreciate the help.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
I just got a set of new 9 inch sharper bars. i had to bend all 4 bolts on both of them to get them to fit. It just takes some finesse. i'd screw the shims to the skis. Maxdlx
Kevin Garceau
My bergstroms fell right into place...on stock skis though.
sd5500
I wonder why the shims aren't the entire width of the bumper.
I'll put em in the vice and see if I can move a bit.
Indy
I ordered 2 sets a couple of weeks ago, one set doesnt fit any of the skis I own and both were single carbide, I ordered triples. No I havent called scott yet, I am sure he will make it right.
sd5500
whats the best way to move the studs without trashing the threads?
I'm sure he'll make it right as well. I just don't wanna wait another 2 weeks.
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
sd5500 said:whats the best way to move the studs without trashing the threads?
Clamp the bar into a vice with the threads sticking up. Thread on a supplied nut. Clamp a vice grip onto the nut and bend it in the desired direction. If you do no posess "POPEYE" arms...use a hammer.
Mikecam
Glue and the screw.
studdog
I've had no problem with them on my Slydogs. Call scott.
DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
- lacroixmotorsports.tripod.com
Dependingon his jig and or how he welds them together they can and will be a little off when they weld these together anywhere the heat will distort and may be off a bit .Give scott a call he is a great guy to talk to and i am sure will take care of u JMO Mine should be here tommorow and cant wait to go try them.
sd5500
Thanks guys!!
I glued and screwed...hey now!!
I viced, nutted, and hammered.
I'll put the skis on in the morning when the glue is dry.
