JD
- Apr 14, 2003
- Manitoba, Canada
- 2016 Venture TF-LE
Just got the parts to switch out that pressed in collar on the 03 RX-1 jackshaft.....Can anyone tell me which way the nut bearing (8FA-17642-00-00) goes onto the collar (8FA-17645-10-00)…The collar seems to have a thin locking ring.....does it get threaded on last????
LazyBastard
The lock-ring goes on the same way as the plastic on a regular locknut. Flat side of the nut against the bearing.
Skydog
Guys can you help me. I told my Yamaha dealer that the jack shaft bearing has been updated. He says no?? What part did they up date i have a 03.
Thank you Skydog
Thank you Skydog
whits-end
- Mar 2, 2004
It's the same bearing. The retaining collar is different, and a new nut retains it. It should be easy to see,if you compare the'03 and'04 parts exploded diagrams. You may not need all the extra washers.
Skydog
JD said:Just got the parts to switch out that pressed in collar on the 03 RX-1 jackshaft.....Can anyone tell me which way the nut bearing (8FA-17642-00-00) goes onto the collar (8FA-17645-10-00)…The collar seems to have a thin locking ring.....does it get threaded on last????
Cool, so if i get the two part numbers up top and a new bearing, my 03 will be all updated?!!
Thank you Skydog
Skydog
Guys do all these parts go on the clutch side or the chain case side?I think he gave me all the wrong stuff. My dealer has no clue??????????
Skydog
Skydog
Skydog
Any one have a pic.?
Thank you
Thank you
